Technical Specifications
Â
ENGINE |
Type |
Liquid-cooled 4-stroke 16-valve DOHC Inline-4 |
Engine Displacement (cm3) |
999cc |
No. of Valves per Cylinder |
4 |
Bore ´ Stroke (mm) |
76 x 55 |
Compression Ratio |
13:01 |
Max. Power Output |
141kW/13,000rpm |
Max. Torque |
116Nm/11,000rpm |
Oil Capacity |
3.4L |
FUEL SYSTEM |
Carburation |
PGM-DSFI |
Fuel Tank Capacity |
16L |
Fuel Consumption |
TBC |
ELECTRICAL SYSTEM |
Starter |
Electric |
Battery Capacity |
12V-4.5AH(Li-ion) |
ACG Output |
0.42kw |
DRIVETRAIN |
Clutch Type |
Wet, multiplate clutch |
Transmission Type |
6-speed |
Final Drive |
Chain |
FRAME |
Type |
Diamond; aluminium composite twin spar |
CHASSIS |
Dimensions (LxWxH) |
2,065mm x 715mm x 1125mm |
Wheelbase |
1404mm |
Caster Angle |
23.3° |
Trail |
96mm |
Seat Height |
820mm |
Ground Clearance |
129mm |
Kerb Weight |
195kg |
Turning radius |
SUSPENSION |
Type Front |
Telescopic inverted fork with an inner tube diameter of 43mm, and a NIX30 Smart-EC (OHLINS) Front Fork with preload, compression and rebound adjustments, 120mm stroke |
Type Rear |
Unit Pro-Link with gas-charged TTX36 Smart-EC (Öhlins) damper featuring preload and compression and rebound damping adjustment, 60mm stroke |
WHEELS |
Rim Size Front |
17 inch |
Rim Size Rear |
17 inch |
Tyres Front |
120/70ZR17 58W |
Tyres Rear |
190/50ZR17 73W |
BRAKES |
ABS System Type |
2 Channel |
INSTRUMENTS & ELECTRICS |
Instruments |
TFT-LCD |
Security System |
HISS |
Headlight |
LED |
Taillight |
LED |
Â
All specifications are provisional and subject to change without notice.
STRONY: 1 |
